3electrons
Hi everybody
Sorry to post it in english but I don't know german. I was using google translator to read threads visit this forum.
I found few people here has compiled libnodave on 64bit linux so I have done it the same way.
I have following problem.
Writing single byte into plc results in error: "desired address is beyond limit for this PLC" - error number 5
area = 132
DB = 99
start = 0
len = 1
*buffer = 0x01 0x00
res = daveWriteBytes(m_dc, area, DB, start, len, buffer);
res = 5
Does any of you encounter that problem? Or I have to figure it out on my own. At the same time reading works perfectly. There is no such problem on windows and linux in 32bit mode.
My environment:
libnodave 0.8.4.5
g++ (Gentoo 4.3.4 p1.1, pie-10.1.5) 4.3.4
Architecture : Intel Core 2
binutils - 2.18-r3
PLC: VIPA CPU315SB
Comunnication is realised via ethernet cable.
Makefile:
CFLAGS = -m64 -Wall -Winline -DLINUX -DDAVE_LITTLE_ENDIAN -fPIC
CTFLAGS = -m64 -Wall -Winline -fPID -DLINUX -DDAVE_LITTLE_ENDIAN -fPIC
CPPFLAGS = -m64 -Wall -Winline -DLINUX -DDAVE_LITTLE_ENDIAN -fPIC
I was trying to debug libnodave ... but I have not much time to understand its internal architecture. I will be also glad for any hints how to fix the bug on my own.
BTW. To the author of libnodave .... good work very usefull library
area = 132
DB = 99
start = 0
len = 1
*buffer = 0x01 0x00
res = 5
My environment:
libnodave 0.8.4.5
binutils - 2.18-r3
PLC: VIPA CPU315SB
Makefile:
