modem 3G / router 2314008
fj.mesa.a
Hello everyone!
I have a client that has a VPN network with a MGUARD and several Modem 3G. In the last modem installation I found a net analyzer EMPRO MA600 (with ethernet adapter) that is already connected to a PLC via ethernet. The EMPRO has IP 192.168.10.64 and below the Modem I have to set the IP in the 172.21.50.X segment. I know I can´t put two ethernet adapters to the EMPRO with diferents IPs, so my question: Can I use static routes in the modem 3G to reach the EMPRO with IP 192.168.10.64 through the IP 172.21.50.X??? If so, how should I do that??
Thanks!!
i´m not sure, but i think you can use 1:1 NAT. With that you can set the internal ip for the 3g modem to 192.168.10.0/24 and on the mguard site you can set the modem ip to 172.21.50.x
Innominate had some examples in there documentiation -> link to innominate
Hi Michael,
i just respond to the post from fj.mesa.a, so he is the guy with the problem :-)
@fj.mesa.a
Like Michael wrote, the best will be you contact the Phoenix Contact Hotline. The guys there are friendly, you get a fast answer and it´s free of charge.
Regards,
gerribaldi
