pfc200 codesys 3.5 homeautomation hilfe gebraucht
hschroyen
Hallo forum leute,
Ich hoffe das ich hier auch etwas in english posten darf. Ich lese und spreche deutch aber das schreiben geht nicht so gut.
So :
I want to use a PFC200 running on codesys 3.5 to have a visu for my family.
My old PLC talked with https://home-assistant.io/ and was using https://home-assistant.io/components/sensor.http/
What I need is a way to talk to the PFC200. I need a way to verify the status of some variables and a way to modify them. (change the status of lights and to check if they are on or off)
I tried several things like MQTT https://home-assistant.io/components/sensor.mqtt/ but most of them failed as I am not sure which direction I should go.
Http get and post look promising but I never found an example or a way to get it working
Modbus is also possible in home-assistant but as far as I can see this is not possible in codesys 3.5...or am I wrong?
https://home-assistant.io/components/sensor.modbus/
So : could someone advice in which direction I should look? Somebody already tried this? My experience with codesys is very low so an example is highly appreciated. :)
Thanks in advance for your help.
I am pretty sure this would help a lot of people as I see on the home assistant page also people looking for a solution
Guten tag
Hschroyen
Hello,
I hope i understand you right:
do you work with e!cockpit or Codesys Target?
If you use e!cockpit you have to assign the modbus adresses in the modbus configurator.
See the Screenshots.
i didnt know how you make this without e!cockpit...
But you can use e!cockpit Trial Version with full features. Download on Wago Homepage after registration.
Hope i could helped.
2016-08-29 13_14_34-Wago E!Cockpit - VMware Workstation.jpg2016-08-29 13_16_49-Wago E!Cockpit - VMware Workstation.jpg
Hello,
If it is CODESYS V3 (maybe this works with e!Cockpit too) there is an implementation for mqtt
https://github.com/kmpm/OSC-MQTT
sure another option is using Modbus.
Attachend an Example how 2 CODESYS V3 Controller communicate by Modbus.
Best Regards
