TIA Trouble wih the profinet Connection PLC S7-1214C<---->Desoutter CVIL II Screw unit
t.hammer
Hello together,
We have trouble with the profinet to PLC S7-1214C
General:
The profinet connection is running with the standard default mapping. We don´t use the fieldbus mapping tool inside the CVIPC2000 engineering tool
  • The problem is following:
    1. The profinet is working.
    2. After the power on time, the plc can't find the device name (profinet) desoutter unit!
The screen shot shows: everything ok and the station is working.
We have following situation after the power on time:
Here can you see the loosing NAME DEVICE: Why loosed the desoutter device his Device Name?
Desoutter said me: the problem come from Siemens!
Have somebody the same situation?
Thanks a lot
Tobias Hammer
Hello,
in the Desoutter Software CVIPC 2000 is a field with the name "station comment" this is the "profinet name" for Desoutter. Do not use _ in the "profinet name" the Desoutter profinet modul cant work with underlines.
Hope i can help.
