beltraja06
Hello,
First, unfortunately, I don’t speak German but found this forum as B&R is much more prevalent in Europe and I’m hoping someone can help me out.
This is my first time setting up a B&R machine.
I am trying to set up an ACOPOS P3 servo with a single axis motor. I was able to communicate to all my devices over Powerlink successfully.
Once Hypervisor's SDM showed my hardware connections were all plugged and good, I went ahead and tried setting up MappMotion for a single axis and MappCockpit.
After adding the MappCockpit, I built my configuration and transferred it. I transferred the configuration to the target and it restarted. But, it will no longer boot back up. It continues to loop in a boot sequence. It seems to be getting stuck trying to load AR Embedded.
I am able to press F1 many times in order to log back into Windows.
I’m not sure how to troubleshoot this. I was going to see if I can reconfigure and do an offline installation, but I’m not sure how.
Can someone provide some guidance on what I should do next?
Thank you in advance!
JB
JB
