server.modules              = (
 #                               "mod_rewrite",
 #                               "mod_redirect",
 #                               "mod_alias",
 #                               "mod_access",
 #                               "mod_cml",
 #                               "mod_trigger_b4_dl",
                                 "mod_auth",
 #                               "mod_status",
 #                               "mod_setenv",
 #                               "mod_fastcgi",
                                 "mod_proxy",
 #                               "mod_simple_vhost",
 #                               "mod_evhost",
 #                               "mod_userdir",
 #                               "mod_cgi",
 #                               "mod_compress",
 #                               "mod_ssi",
 #                               "mod_usertrack",
 #                               "mod_expire",
 #                               "mod_secdownload",
 #                               "mod_rrdtool",
 #                               "mod_accesslog"
 ## a static document-root, for virtual-hosting take look at the
 ## server.virtual-* options
 server.document-root        = "/jffs/www/"
 ## where to send error-messages to
 server.errorlog             = "/jffs/Data/lighttperror.log"
 # files to check for if .../ is requested
 index-file.names            = ( "index.html" )
 ## set the event-handler (read the performance section in the manual)
 # server.event-handler = "freebsd-kqueue" # needed on OS X
 server.event-handler = "poll" # needed on OS X
 proxy.debug         = 0
 #### accesslog module
 accesslog.filename          = "/jffs/Data/lighttpdaccess.log"
 ######### Options that are good to be but not neccesary to be changed #######
 ## bind to port (default: 80)
 server.port                = 80
 auth.debug = 0
 #auth.backend = "plain"
 #auth.backend.plain.userfile = "/jffs/opt/etc/lighttpd/pass.TXT"
 auth.backend = "htpasswd"
 auth.backend.htpasswd.userfile = "/jffs/opt/etc/lighttpd/lighttpd-htpasswd.user"
$HTTP["host"] =~ "(your.dyns.address.com)" {
   $HTTP["url"] =~ "" {
    auth.require = ( "" =>
         "method"  => "basic",
         "realm"   => "Bitte geben Sie Benutzername und Passwort für den geheimen Bereich ein. ",
         "require" => "user=sps"
     $HTTP["url"] =~ "^/cgi-bin(.*)$" {
         proxy.server  = ("" => (
             ("host" => "192.168.0.20", "port" => 80)
 $HTTP["host"] =~ "192.168.0.1" {
 $HTTP["host"] =~ "(router)" {
