Step 7 PROFIBUS Watchdog Timeout ONLY on Power-Up (Siemens ET200S) - CPU Enters STOP Mode
Davin
Hello esteemed experts and colleagues,
I am working with a Siemens S7 automation system and I am currently facing a critical and persistent Watchdog Timeout issue on our PROFIBUS DP network.
1. Hardware Overview
  • Master: Siemens S7 CPU [Specify your CPU model, eg, 315-2 DP]
  • Slave: Siemens ET200S Distributed I/O (Interface Module: [Specify IM model, eg, IM 151-1])
  • Software: [Specify software version, eg, Step 7 V5.5 ]
  • 2. Detailed problem description​
    The fault is highly specific and predictable:
    1. On Initial Power-Up: When the system powers up, the CPU immediately detects a fault and transitions to STOP mode .
    2. Diagnostics Buffer: The Diagnostics Buffer confirms a Watchdog Timeout for the specific ET200S PROFIBUS address [Specify DP Address, eg, Address 3]. This indicates the ET200S failed to respond in time during the initial communication handshake.
    3. Manual Recovery: The issue is completely resolved when the CPU is manually cycled from STOP to RUN . The communication is established instantly, and the system runs error-free until the next power cycle.
you can set the amount of time the CPU waits until all slaves respond at startup. If this time is exceeded, the response depends on the “Target/Actual Expansion” setting.
CPU properties > startup tab: increase the monitoring time. Should be something like “Completion notification".
PS: I don't have an English version, so the wording may differ slightly.
Is the DP-Remote at the Same Powersupply as the CPU? Then perhaps, the Remote boots up to slow. but is there at the Run-Stop-Run Cycle.
You can either load the according OB to avoid this (But thenthe cpu will run without the DP-Remote if it fails, you have to take care of that).
The OBs would be O121, OB82 and i think OB86.
or you rise the time for the ["Finished" message from Module] in the Startup Monitoring of the CPU
