larry
I've been struggling with the problem for a long time and need everyone's help, thank you
If the pump is stopped after a certain delay in working mode or standby mode, why should the subsequent program delay a cycle to generate the pump command? This command is located in Network 6
I took a closer look at the process and guessed that this waiting for a cycle problem should have nothing to do with the process running?
